Carburator problems settings..????
Larry59
I have a 58 B-311 with 146 engine. Took carburator off and found no marking on the butterfly as same say might be. Found only on back side.. letters SK #687. First does this mean anything to anyone?
Second.. I did get a carb kit for it from auto parts store. But it contains no paper work other then a note says.. 2 needles..make sure which one is your size before installing. Also there is the little measurment stick to check or set the Floats. However , There is nothing to tell me what that measurement might be to read on stick. Any help...
Kit was put out by , Walker Innovative Engine Management Solutions, #778-505
Been on internet looking can't find the settings I need. Also what is the settings on the adjustment screws?
Also don't tell me to go to the Case side... been there and got no answer. *S
Larry, look in the box a little it better. A lot of times the instruction sheet sticks in the box under the inside box that has the parts in it. If you don't find it drop me an e-mail and I'll scan you a copy of it. I just walked out to my shop and have the sheet right here in the desk. Float setting is a 1/4 inch from the gasket surface to the float.
Hobby farm
Go ahead and scan that for me rich..thanks .. sent email to on it and about Dodge getting fix for 400.00 for a dan fuel pump and labor ..
