Carburetor cleaning
300jk
Im working on a Marvel carb off our 1650 Oliver. I didnt take out the throttle plate or choke plate. How long can I soak it in Berryman carb cleaner. Its been so many years since Ive had it apart I cant remember if it has anything plastic or rubber that will get eaten up if I leave it in too long. Thanks.
I have usually left them in one hour...depending of the severity of the carb- water rinse and air dry. Good luck.
Most of the time I soak one over night. I then spray it off/out with spray carb cleaner then blow it out with air then poke all the passage ways out with a torch tip cleaner tool then spray blow and poke again and I do the last 3 3 or 4 times
I do have completely stripped down minus the throttle and choke plate. Dont want to ruin anything leaving it in too long is all.
Won't hurt it to leave it as is.
The new cleaners aren't near what the old ones were.
I never take throttle shafts or choke shafts out unless there is a good reason. Too much danger of twisting off a screw.
It depends on what type a seal if any is on the throttle shaft. On the IH carburetors like used on the six cylinder engines, the later seal will swell up like a balloon and shaft will move very hard.
If there is a seal and you have a kit the new seal will most likely in the kit.
