Carburetor Rebuild Kits
MTbob
The Carburetor Rebuild Kits here: http://www.ytmag.com/cgi-bin/store/model_parts.cgi?SearchArea=FORD&&md=8N&cat=Fuel%20System%20/%20Air%20Intake&r=mcats
doesn't have the rights shaped gasket for my carb, (the typical cast iron Marvel-Schebler).
Do I ignore the photos?
Also, how would I determine the right model number carb that I have (for 8N #188572) Marvel-Schebler TSX33, TSX241A, TSX241B, & TSX241C, Ford 8N9510C?
Is it worth upgrading to a new Zenith carb, is it worth $200
(quoted from post at 09:44:11 05/23/11) The Carburetor Rebuild Kits here: http://www.ytmag.com/cgi-bin/store/model_parts.cgi?SearchArea=FORD&&md=8N&cat=Fuel%20System%20/%20Air%20Intake&r=mcats
MTbob;
This is the kit you need to buy:
Carburetor Kit, Comprehensive - For models from 1939 to 1952, carburetor part #: Marvel-Schebler TSX241A, TSX241B, & TSX241C, Ford 8N9510C. Kit contains parts necessary for major carburetor overhaul, including a Viton float valve. For 2N, 8N, 9N. Does Not include Float. (Part No: C546V) $37.50
This kit has everything you will need to completely, overhaul your M/S TSX carb for your 8N!!!!
Make sure to clean out all the passages, inside your carb, before you install the needed parts.
Click here and read this YT Post, for carb cleaning info.!!!:
CARB CLEANING!
Gary :)
