Carburetor Rebuild Kits
MTbob
OK, so I got the kit and the gasket does not match my carburetor. Do I cut it to fit?
MTbob
The Carburetor Rebuild Kits here: http://www.ytmag.com/cgi-bin/store/model_parts.cgi?SearchArea=FORD&&md=8N&cat=Fuel%20System%20/%20Air%20Intake&r=mcats
doesn't have the rights shaped gasket for my carb, (the typical cast iron Marvel-Schebler).
Do I ignore the photos?
Also, how would I determine the right model number carb that I have (for 8N #188572) Marvel-Schebler TSX33, TSX241A, TSX241B, & TSX241C, Ford 8N9510C?
Is it worth upgrading to a new Zenith carb, is it worth $200
GB in MT.
Quoting Removed, click Modern View to see
MTbob;
This is the kit you need to buy:
Carburetor Kit, Comprehensive - For models from 1939 to 1952, carburetor part #: Marvel-Schebler TSX241A, TSX241B, & TSX241C, Ford 8N9510C. Kit contains parts necessary for major carburetor overhaul, including a Viton float valve. For 2N, 8N, 9N. Does Not include Float. (Part No: C546V) $37.50
This kit has everything you will need to completely, overhaul your M/S TSX carb for your 8N!!!!
Make sure to clean out all the passages, inside your carb, before you install the needed parts.
Click here and read this YT Post, for carb cleaning info.!!!:
CARB CLEANING!
Gary :)
One kit will fit all the above mentioned MS carbs. Do you have an MS carb? Can you post a picture of how the gasket does not fit?
(quoted from post at 12:52:01 05/27/11) One kit will fit all the above mentioned MS carbs. Do you have an MS carb? Can you post a picture of how the gasket does not fit?
b:42875d0b32][i:42875d0b32]
I have a feeling that he does not have the M/S carb. that he stated he had.
His statement from his other post:.......
" my carb, (the typical cast iron Marvel-Schebler)."
The kit I posted for him, was based on that statement.
As you say Harold.....If it is an M/S TSX, with any of those #s, that I mentioned, in my reply, to him......WILL fit!!!!
MT bob;
We need to see a picture of your carb, to see what make/model you actually have!!!!????
GB :?
[/i:42875d0b32][/b:42875d0b32]
Well I just broke and stripped out the brass fittings on the carburetor I was trying to fix, so it looks like it's a moot question and I'll be needing a new one. But, thanks for your time.
If you have to buy a replica marvel then get the gold one and not the cast iron. Several well respected members on here have sworn that no trouble came from them.
did you just break a jet? they can still be extracted.
PS.. the gaskets for most MS carbs inthe 241-4xx and 5xx range are near identical..... in fact..the last 2 kits I bought.. the 428 and 241 were exactly the same..
soundguy
