Updraft was usually used to get the carb down low for gravity fuel feed.
Side draft were mostly for performance, ease of access, think motorcycle, and hood clearance, think low center gravity sports cars.
Down draft more equal fuel distribution on V and boxer engines, better fuel flow, not fighting gravity, ease of service, reliability.
I've had machines that had all 3 types and the side draft was used on the fastest car I ever drove and it came stock with 2-2 barrel side draft Weber carbs. Speedometer in that car read 200MPH
Gene ..... did the original post mention anything about an engine not working well? Steve seemed to hit the nail on the head with his reply.
Also a 1929 Caterpillar fifteen has a side draft. Carb is on left side of engine and manifolds are on the right side. Hole goes right through the middle of the block. Model "A" Ford has an updraught zenith most of the time. A 1942 Chevy straight six has a down draft Carter.
I agree with you.
On both my Farmall and Jubilee the carbs dripped gas on the barn floor. I fixed the problem with a 12v solenoid that shuts off the gas when I turn the key off.
I've had some side draft carbs on Briggs engine on riding mower. When the carb leaked it filled the crankcase with gas. Fix that problem with a 12v solenoid too.
I have drained 5 plus gal of gas and oil mix out of the oil pan of an 9N more then once due to the float not closing and then it fills the pan with gas. Also seen it happen on other tractors.
