I have a Marvel Schebler carb on my ford I rebuilt. I put it on started the tractor but wouldn't run long and die.
It did this several while I tried to adjust it. I took it off and apart and noticed that when the float dropped the
needle didn't always drop from the seat. I took them out and the hole in the new seat was larger than the in the
old seat. I put the old seat back in with the new needle put it back on the tractor. Now it does run maybe 5 minutes
or so but will die. I pulled the plug on the carburetor to drain gas I got about a half cup in 5 min. Can some
one tell me what size the hole in the seat should be. Should I get a new needle and seat. Also I wounder if the float
needs adjusting and how do I do that.
As always thanks for any help.
