justjim
my 8n has been running but now it doesnt get gas to the cylinders, but gets gas to the carburetor??????????? any ideas?
thanks
(quoted from post at 18:26:14 02/21/11) my 8n has been running but now it doesnt get gas to the cylinders, but gets gas to the carburetor??????????? any ideas?
thanks
If you do get liquid gas into the cylinders, then something is wrong & wet plugs don't make for a running engine. On what do you base your conclusion of no fuel to the cylinders? Not to mean that such is impossible, but often that turns out not to be the case.
You might check the air filter,as if you have spark[I'm assuming],and gas and at least a minimum of compression,then it should start.That having been said,you probably have gas-fouled plugs,or sticking float,seeing that you said you have gas in the cylinders.---lha
my brother said the plugs are dry?
does that mean that is not getting gas to the cylinders? i told him that dont mean is not gettin gas?
(quoted from post at 19:20:33 02/21/11) my brother said the plugs are dry?
ou are correct.
