Case 10 sickle bar mower pitman
jeffreyi
My (much used) Case 10 semi-mount mower came with a metal pitman. I rebuilt the other parts, new sections, clips, wear plates,
guards, belt. It was running nicely until it didn't. Investigation revealed that the metal pipe pitman is bent, and it is a
cobbled up replaced part. From the parts book this component is supposed to be wood, which in retrospect makes sense. I intend to
make a wood one out of some dry black locust boards I have. The part number is T11069. The (now bent) pipe pitman is about 41
inches long. Aftermarket wood pitmans (part no. M22184, available in lots of places) that supposedly fit this mower are 35 11/16
inches long, and have a slot. I don't think a slot is needed, and the length seems wrong. Does anyone here have an authentic wood
pitman for a Case 10 mower, and, how long is it? I did see another post where someone said the wood pitman for this mower should
be 41 inches. Thanks in advance!
If no one gives you the proper length, you can figure it out. The knife sections should move equal distances back and forth on each side of the guard.
We had a Case #10 mower for years and replaced many pitmans on it. 41 inches is what I remember. Never use metal for the pitman. It is designed to break instead of busting something else.
Don't see the book but if I remember right there was a slot on the drive end that was fitted with a metal plate in the slot and bolts through the wood and plate. wish I had the book still but probably let it go with the mower.
The slotted end of the wooden pitman accepted a flat metal plate that bolted into the pitman slot and extended back to the eccentric bearing stub on the pulley. The steel bearing plate accounts for the wooden pitman being shorter. as it extended the working length of the total pitman assy.
Loren
I havent had time to track down what this Pitman fits, but I did get some pictures.
