case 1030 hydraulic suction screen
I've never had a 1030 but do have an 830 and the hydraulic suction screen is mounted on the inside of the rear plate which also holds all the PTO gears and hydraulic pump. Remove this all in one piece and there is the screen bolted on at the bottom. (Check your parts book). On my 830 the screen partially disintegrated and let in some tiny bits of material which looked like nylon. Wondered if they came off an oil slinger gear up front somewhere (any better suggestions? They blocked some small holes in 3point lift valve) I brazed a piece of stainless gauze in place of the original and have had no problems since, around 30 years.
