Case 1070 low pressure on C3
wood2010
New to me 1070 that I'm learning a lot on. I shimmed my flow divider spring to get up to 200 psi and will order a new spring. Lube is showing 75psi, C1 = 175psi, C2 = 175 psi, C3 = 65 psi, and C4= 165. Can I get the spool out of C3 or will I need to plan on removing a lot of other stuff? I have the manual, but looking for any tips from others that have done this and what I should look for. If the spool is loose and moves freely, is my next step to remove the cover and see if the passages are filled with debris? Thanks
If you have 65 Lbs that proves to me that C3 pilot spool is working, check the hitch in second and 3rd powershift, my guess is the C3 Clutch circuit has a massive leak and you will probably be splitting it. If the hitch has no lift or the remote pressure is gone the flow divider has sent the hydraulic oil to supply the leak in the power shift. A flow test would be the right way to diagnose it and someone familiar with the test setup and procedure, a flow test would show how many GPM leak the clutch has.
If you find a tech with a flowmeter and he is not familiar with the Case system, I will talk him through it, the power shift can be diagnosed through the remote couplers after you get the tractor set up to do it.
