Jeff Phinney
I have an early Case 1070 with the powershift. I was pulling a chisel plow with it, lifted it up turned around put it back down went about 50 feet and the tractor stopped moving. There wasn't any unusual or alarming sounds made when this happened. With the tractor running I can shift the powershift and the engine still surges like it always has. With the power shift in any position I can shift the range transmission into any gear without any hesitation or grinding. It still has power steering, brakes, a working 3 point, and pto. Yesterday I drained the fluid out of it and discovered some small steel chips in the fluid.
Any help to point me in the right direction would be greatly appreciated.
Jeff
Jeff
