anthonypitre
I have a case 1070 tractor serial number after 8675001. I don't know what to do. The tractor was given to me and needed some work. I installed a new clutch, power shift valve and a new hydraulic rear pump. The tractor was running just like it should until about 100 hrs on it.
At start up I have to hold down the clutch for at least 1 to 2 mins to build up hydraulic pressure and to hear that windy noise that it normally makes to shift gears. Once hydraulic pressure is reached and while driving when a depress the clutch again it takes about 10 to 20 sec do reach hydraulic pressure again.
Power steering, Pto and lift arms both work. Is there a valve that might be stuck that is supposed to hold the hydraulic pressure. I'm all out of ideas and would like some help.
Anthony
