Keckr
My case 1175 has really low transmission pressure whenever I first start it up. The pressure increases as the oil gets warmer. I was curious if it could be a sump screen. And if it was hard to get to. The tractor appears to only have one hydraulic filter. Not sure if there is an internal filter. TYIA
Could be the screen. As a test you could apply compressed air backwards with the pump removed to see if it gets temporarily better.
Only the one filter on 8 speed tractors. Getting it out to service involves removing the PTO gearbox. Not super hard, but not easy with big heavy parts to handle.
I think you meant to say you need to remove the PTO housing to clean the intake screen. The hydraulic filter is on the right side of the tractor.
You might want to put a 300 PSI gauge on the flow divider where the dash gauge is plumbed to and see what it shows, all the pressure is for is the PTO ,180 to 210 PSI is all thats needed
