I have a Case 1184 with a solid Diesel engine. Solid runner.
BUT..
Needs new water pump (engine overheats and I have cleaned the system, replaced cap/thermostat/hosesno leaks it just heats up and blows it out the overflow)
PTO works
3point hitch raises but needs to be pushed back downhydraulic fluid going into some mysterious dimension but not onto my garage floorabout 5 gallons per year the top point of the 3 points is a small hydraulic cylinder that seems to be stuck and the adjustment switch is stuck fast in placecan t be moved without breaking it off.
Tires and rims are near the end, front end is near desperate.
Hydraulic steering system runs off engine oil? It screams loudly with any movement and seems slow to respond but worksfor now.
Can anyone tell me if this is worth going throughare parts available? Or should I sell it and make it someone else s problem and buy something better? Recommendations? (Newersince I m older and getting sick of fixing constantly!)
Thanks to all you Case expertsi m stumped!
BUT..
PTO works
