Case 1370 brake bleed location?
wilson2k3
Having a tough time finding the location of the screw to bleed the brakes on a Case 1370. All the manuals I have seem to look a bit different detailing the location.
If memory serves me correctly, been 10 years or more that I had to do mine, they are on top of the rear axle housings where the bump is for the planetary and the actual transmission case, mine had caps over them, I remember it was a real pita to get to and I'm a little fella!
There is a stand pipe on the differential housing where the connection is made to the brake piston assembly inside. The brake line attaches on top. There is a block on the top of the stand pipe that has the bleeder in the side of it. Here is a picture I found online from a 90 series that would be similar. It is directly top/center behind the two lines running horizontally.
