aaronknodel
Hi all, I have a case 1370 that I've been working on lately, previous to the latest repair the powershift worked perfectly fine, I removed the powershift control valve assembly on the passenger side of the transmission (the repair had nothing to with the powershift I accidentally removed it instead of the range shift cover! oops!) after I put the powershift control valve assembly back on the shifter is totally loose, there is no resistance between gears at all, in fact if you let the shifter go it will slide all the way down to 3rd. The power shift still works on all gears though, you just need to hold onto the shifter the whole time or it just slides forwards. Anyone have ideas for what I may have done wrong when i put the control valve assembly back on? I thought I had put it back exactly as it was but obviously something has gone wrong, any help is appreciated! thanks
