is that the sensing leaver ?(quoted from post at 09:50:08 04/12/20) Have you checked the draft control? Just a thought
yes the cable is good an it moves the leaver underneath(quoted from post at 10:06:55 04/12/20) Yes, the cable broke on my 1170 one time
and the same thing happened, the lever
moved but didn't actuate anything so be
sure your cable is moving
.... if it is the rock shaft how do I loosen it up ??(quoted from post at 11:07:11 04/12/20) Have you tried forcing it down? It's possible the rock shaft has tightened up from non use.
I jumped up and down on the lift arms got them down about halfway but don't want to go on down(quoted from post at 13:25:21 04/12/20) If it works but is just stiff just put something on heavy enough
to make it work and use it.
