john0107
Not into antique tractors but have a case 190 with a bucket onthe front. Tractor needs a lot of work. Don't know if I should put $500 cost to repalce rear axel/drive motor and steering box. Have a good deal on a Case 448 in good condition thought of butting the bucket on that only use it like a wheelbarrow or to move dirt around the yard
any ideas
The 448 is a far superior tractor, strength-wise. Put the loader on it and then put the 190 up for sale, as is.
Do you know what's wrong with the trans-axle?
Tom thanks for the reply
Yes the left rear axel broke. The tractor moves real slow forward and I changed the oil and cleaned the filter so now I have been told it is the drive motor. and the sterring box is broke besides this 190 paint is real bad (ugly)
The 448 is $600 no attachments but supposedly stored inside
thanks for the advise
It's not too hard to find a replacement axle shaft for the trans-axle. Check with Joe Hemmi of Joe's Outdoor Power in Michigan. Or send me an e-mail and I'll try and find one for you.
You say that you changed the oil and cleaned the filter. I'll assume that you are referring to the hydraulic pump's intake screen that is located inside the trans-axle. If so, that's good. However, if you did not refill the trans-axle with motor oil in one of the following grades, 30W, 20W50 or 15W40, then you have erred. My guess is that you used some sort of "hydraulic fluid" in it and that would be a big mistake. Common hydraulic fluid will not transfer the engine's power to the drive motor properly.
Now if you did get it right, then you can't expect to get much forward speed with a broken axle shaft. You need to clarify that issue with me before condemning the drive motor.
I'm not saying that you don't have a drive motor problem but those motors are pretty bullet-proof. New motors are still available and can be bought for a fairly reasonable price.
The above is not intended to talk you out of buying the other tractor. I think that would be a good move because the tran-axle and front axle of the 400 series are much stronger, as is the frame, especially for loader duty.
There is a market out there for the 190, once you've stripped the loader off of it. All of the old 100's have slipped into the "collector tractor" catagory so you should have no problem getting a few hundred bucks for it, as is. Please provide me with a reply on the above.
The tractor moved real slow forward when I first got it so I change the oil to 20/50 motor oil and cleaned the screen, it ran good except for real slow forward and fast reverse then I broke the axel and it did not move at all.
just looked at an Ingersol 4018 with 3 point hitch $1000 is this close to the case 488 $600
what would the 190 be worth as a parts tractor
The 4018 is the newer version of the 448. Essentially the same tractor but Ingersoll turned the engine 180 degrees in the frame, mounted an electric PTO clutch on the crank's stub shaft and drove the hydraulic pump off the front (flywheel side) of the engine.
The only downside is that all the snocasters and decks that were made before 1989 won't work on your tractor. Turning the motor around meant Ingersoll had to make a right discharge deck instead of the left discharge models they previously used and while the basic snocaster is the same, the belt drive mule pulleys are mounted differently because the belt is rotating in the opposite direction.
4018's came with Vanguard's and Onan Performer 18's. Both are excellent engines the Briggs will be cheaper on fuel but the Onan delivers much better torque.
A good running 4018 with the three-point is a good buy for only a grand. Currently, the HH-34 hitch will bring $400.00 plus on e-Bay so if you need a three-point, take a hard look at this tractor.
Even a parts tractor should bring $250.00. 190's are getting harder to find and so the prices for them are on the rise. How complete they are is important. How straight the tin is will also be important. The broken axle is not a big deal. Annoying yes but not a deal-breaker. Used axles and used motors do appear on e-Bay.
I'm a collector so the flaky motor wouldn't matter to me because your tractor would become a trailer queen. As long is I could start it up and move it on and off my trailer, ground speed doesn't matter.
Tom
By removing the front power take off will I be able to run the pump for the front bucket. You said they turned the engine so the pulley runs different direction. Don't really need the 3 point but it is there. I am located in RI where are you
I'm north of Toronto, Ontario actually.
If the loader you have, has it's own pump, then I recommend that you don't use it.
The stock hydraulic system on any Case or Ingersoll GT is more than capable of looking after any FEL ever built for a GT or even one for a full-size utility tractor.
The only issue would be the relief valve. If the control valve that operates the loader functions has a built-in relief valve, then forget about using the extra pump. That control valve should have one hose coming into it that supplies pressure from the pump and another hose leaving the valve that delivers oil back to the reservoir that is likely attached to the pump.
If you buy another tractor that has the rear mounted hydraulic PTO valve, then the loader valve would get plumbed into the system this way.
Trace the high pressure line leaving the pump on the tractor. It should go to the "IN" side of the PTO valve. The "OUT" side of the PTO valve will go to the "IN" side of the travel/lift valve under the tractor. This is where you make your connections. You remove the "OUT" line coming from the PTO where it attaches to the "IN" port of the travel/lift valve. You add a hose to that "OUT" line from the PTO and attach the other end of that line to the "IN" port on your loader control valve. The "OUT" port of your loader control valve gets connected to another hose which then goes back to the travel/lift valve and connects to the "IN" port. That completes the hydraulic circuit. While it might sound a bit confusing, it's really very simple and it cleans up your tractor.
Just so you understand, there isn't room in front of the engine to put a pump for the loader. At best, you could belt drive the pump off of the PTO clutch pulley but you would have to fabricate a bracket system to hold the pump solid plus an adjuster to allow belt tensioning. To me, is is more work than what I described previously. And if it turns out that your loader has the relief valve in the pump and not in the control valve, then I'd just buy another control valve that has a built-in relief so I could get away from having to mount that other pump and string those hoses.
And on top of it all, the pump you have will likely be the wrong rotation for a 4 digit tractor. However, you could mount the pump backward to solve the rotation issue. How is the pump driven currently on the 190 you have? Is it belt driven and mounted to the side of the engine or direct shaft driven right off the front of the engine?
e-Bay the three-point if you feel you will never need it and recover a substantial amount of your purchase price.
I also wonder what the setting is for the system you have for the loader. If could be quite a low relief setting. I think that I would want to put a guage on the hose going to the bottom of the loader lift cylinder to determine how much pressure the relief valve blows off at. This knowledge would be important. Glycerin-filled guages that read pressures up to 3000 PSI are cheap ($20.00) and easy to come by at places such as Northern Tool or even local hydraulic shops.
You just need to remove the hose, insert the correct TEE fitting and then adapt the guage to the TEE. Run the tractor at full speed and apply full downpressure to the loader lift cylinders while watching the guage. Whatever reading you get is the max pressure the relief valve is allowing the pump to develop.
If you get that number, let me know as it will shape my advice.
Tom
Thank You. You give a lot of information to think about if I ever get this project finished I will let you know
Thanks Again
Tom
I purchased the Ingersoll 4018 and will pick it up today. It runs good and does not look bad at all.
Just wondering if you wanted to see pictures of it I will send them to you. Once I get the bucket off the Case 190 I will take some pictures of that also if you are interested, know it is a long distances
Thak You for all your help.
My email address is [email protected]
John
