DJ54
Trying to help a young fellow out on another tractor forum. It appears he has a 200B. It has the dual range transmission,and hand, multiple plate clutch.
I went to the Case/IH search for parts page,and came up with nothing. I tried 200B, 210B, 211B, then all without the "B", and still nothing.
I searched the manuals, and did come up with the parts book, and two different OM's. Seems strange they have the parts book, but yet, do not list anything about it, when you do a parts page search, by entering the model.
I did a Google search, and did get a Tractor Data page, showing some info on it.
Other than the engine, is the drive train the same as the 300B series..??
Looks like he may have to get a OEM parts book, to make sure he gets the right parts, or just look them up. Just thought it was strange Case/IH does not list the tractor.
Hoping "Case Nutty" can shed some light on this, since he has one...
I have a parts book for the "200B" tractors some parts are the same on a 300B but for the most part the "200" was its own unit, let me know what parts you need and I can scan my book pages for you if you like cnt
A major difference in the two is cubic inch displacement. The 200 is a 126 cu. in. and the 300 is a 148 cu. in. I've been told (here) that a 300 piston/sleeve kit will fit the 200B block, as the 126 stuff is scarce.
You can buy a 200B parts book here at Yesterday's Tractor. John Saeli is correct the hand clutch is illustrated on page 48. The backing plate is A7107. The pressure plate is 6139A. The six driven plates are A7102. It's getting to the point that to ask CNH about JI Case, you might as well ask about John Deere.
Thanks for all of the replies..!! Since the 200's are a bit of a different animal in places, may suggest to him to find a parts manual. The clutch and brakes seem to be the main issues at this time. I was thinking if the brakes were the same on it as the 300's, I could offer some advice to him on them. I did a seal replacement on my 310B a couple years ago, and info I received from here, made the job a LOT easier..!!
As far as Case parts from Case/IH, I never had the first problem ordering what I needed. Took the model,serial, and part number to the man, and he had no problem finding it. Of course nothing in stock anymore, for about anything, but always had my parts within 3 days.
All of the seals I replaced were from a place in N.J. that handels NOS CR seals & bearings. Just cross referenced them through the NAPA site, then in turn searched their site. At the time, all were at about 50% of NAPA, or Motion Ind, although it took about a week to get them. Wasn't in that big of a hurry, so it wasn't a problem.
I will probably also suggest he check out this forum, and ask directly to you guys. Hate to be the middle man..., but willing to help where I can.
Hello. I"m the one who asked on the other forum about the 200b case tractor. Just looking here and thought I"d join. Going to try and split it next week and take the clutch to get it relined. A guy up the road rebuilds pressure plates and relines clutch discs. Seems to be real reputable too. I"m hopeing that the pressure plate is just weak. Looking the a hole in the bell housing the bolts in the plate look new. But can"t see the clutch it"s self. I looked for a manual in a PDF format but no luck. Can"t seem to find one online either. Thanks for the help so far I am sure I"ll be asking more questions.
(quoted from post at 11:02:57 02/19/12) Hello. I"m the one who asked on the other forum about the 200b case tractor. Just looking here and thought I"d join. Going to try and split it next week and take the clutch to get it relined. A guy up the road rebuilds pressure plates and relines clutch discs. Seems to be real reputable too. I"m hopeing that the pressure plate is just weak. Looking the a hole in the bell housing the bolts in the plate look new. But can"t see the clutch it"s self. I looked for a manual in a PDF format but no luck. Can"t seem to find one online either. Thanks for the help so far I am sure I"ll be asking more questions.
Hope I'm not being overly simplistic on this one but, if you are new to these tractors there are a couple things to check before splitting.
(1) does the clutch pedal have an inch or two free travel before it feels like it touches the throwout bearing, if the pedal is tight against the floor board a clutch in like new condition will slip. If no free travel lengthen the rod that goes into the clutch housing at the clevis at the pedal.
(2) are you sure the hand clutch is not slipping and making you think the main clutch is slipping. The hand clutch should snap in with a good healthy snap, it is readily adjustable through the top cover, if you are in doubt a couple of notches of adjustment will help you find out. ,Snap the clutch out of gear, locate the adjusting pins and pull the short one out and turn the yoke till the long pin snaps in and repeat this till the lever snaps in firmly. Replace the cover and see if that helps it from slipping.
mEl
If u don't mind I'd like to see the pictures to see how it comes apart inside. My email is on here [email protected]. Are the manuals going to show pretty exploded pictures? Is what they have the parts or service manuals? I'd like to find a cpl different pictures of the tractor to use as a comparison. Thanks.
Brian I do not have a service manual on the 200B but I do have a parts book and will scan you the pics you need, a mEl stated above if it has the hand clutch it is seperate from the foot clutch and I have seen them need adjustment that will make you think it is the foot clutch slipping, if you are not sure if you have this I will take a few pics of my 200B for you to see what we are referring to, I have a SM for the next bigger tractors and they will be the same as far as tear down/repair goes, I will dig out my books and start getting the scans you need and will start a new post for you with the info, I will also go and take a few of the 200 for you just in "Case" you need them for referance also cnt
that will be great. what makes us think the clutch is bad is you can put it in gear and let out the clutch and it takes a few seconds to actually engage. once it does you can be on flat ground and it moves but if you get on a small hill it will slip bad enough it will stop the tractor. if you can get me info on adjusting the hand clutch we will do that. we adjusted the foot clutch but it didnt help. and dont see an adjustment for the hand clutch. you guys have been great so for. thanks. we got the lift working last night, all it took was hydro in the right place,lol. it raises and lowers but not all the way. we are going to bleed the lines today. i feel better about buying it now since we got the lift working. i got the tractor, a set of plows, and a 5 ft bushhog for 1100.00 it starts and runs great. just a few little bugs. thanks again for all the help. brian
Brian I posted the info you need on the first page to you, my e-mail is open here to if you like send me you e-mail address and I will send attcahments to you that will be easier to read and will be easy to print if you like cnt
