Case 2090 hyd remotes not working
Aaron87
New here to the group....Hooked our disc up the other day to move and neither remote 1 or 2 would operate disc cyl... made sure Trans axle level was full which it was... steering, brakes, and Powershift all worked... any help appreciated thanks
Probably 90% of the time the reason remotes don't work is because the couplers did not fully couple up and
open.
If there is residual pressure on the coupling it can be near impossible to fully connect.
Is this tractor new to you? Are you used to the older
Cases that the remotes were split side to side? I
believe on that series they went to a configuration
closer to other brands, the up outer coupler matches
to the next coupler diagonally down low next to it, so
slightly closer to the center. See the picture in this T
House add showing a hydraulic third link connected.
Example
Yes sir... remotes look identical to the link you said... we purchased the tractor from my grandfather when he stopped farming to use.. haven't had a issue with the remotes until now.. it's not the disc because my cousin used the disc just days before and said disc functioned normally
