Case 2090 powershift valve
kenney970
My 2090 powershift valve is sticking occasionally.It has a rebuilt valve from Elmers Repair. Just wondering if anyone has added a filter to supply line to valve. Thanks in advance.
Ken, there is a suction screen in the transmission and the oil goes from there to a charge pump then to the main filter housing where all oil to all systems is filtered. I believe the standard filtering arrangement is more than adequate. Not all filters are created equal and I never ever use anything but Case filters with the fiberglass filtering medium. Early we tried using paper pleat and moisture from condensation would swell the paper up and give a filter light. I would beware of any filters of the paper variety, Case has or did have a High performance filter for those tractors. I hope you are running HYTRAN ULTRA in your system! Those two things I am stubborn about, Major damage can occour if the wrong oils are used. If the proper filters are used and the bypass is good Case's filtering system is just fine.
