Case 2090 pto seal
Gard3599
What are the steps to replace the pto seal? I see there appears to be a plate with two bolts that needs to be removed.
Hi,
If you talking about the big outer seal that can be removed without taking anything off. I have done many of them you will get a little oil.
Marlin
like 2290 said if its the outer seal leaking easy job, I park them with the nose down to ease off the oil back pressure,, if the oil is coming from between the shaft and splines its a tear down of the pto unit to replace a bad oring
(quoted from post at 07:50:52 03/16/21) like 2290 said if its the outer seal leaking easy job, I park them with the nose down to ease off the oil back pressure,, if the oil is coming from between the shaft and splines its a tear down of the pto unit to replace a bad oring
Thanks for the info!
