Case 2094 and 2294
I'm looking to buy a Case 2094 and a case 2294 the 22 for a planter tractor pulling a 12 row NT planter and the 20 for a hay cutting tractor pulling a 10'6" discbine. i currently have a AC 7050 and a Case 1170 are these comparable replacements and or are they good tractors for the job i'm looking to do?
I can speak for the 2094 in the hay field. It will more that do any work required, it won't feel the cutter, even in the thickest of sorghum Sudan hay. The power shift is great for cutting and baling. Not too bad on fuel either. I would think the 2294 would handle the planter fine also unless it is no-till, may grunt a little more in that case.
FE
the 2094 is listed as about 110hp stock, the 1170 would be about 120 but I would think that the 2094 should handle anything the 1170 does with out to much difficulty, the allis you have I think is a little over 150hp so the 2294 will be about 20hp less however I think it should work for you in stock trim and if need be they can be turned up a Little by a good diesel mechanic with out having to worry about the powershift.
I use a 2294 for all my haying and field work. It handles a int 140 4 btm blow great. I use it to pull a Hesston 4910 ton baler as well. You can"t go wrong! Good cab, decent lighting, good AC, very dependable! USE HYTRAN!!!!!
The 2094 will handle the planter just fine. I pulled my 12 row for several years with a 2094. Also have used a 1070 and a 1896
