Case 220 ignition diagram issue
Hello Friends! I am working on rewiring a case 220, and I ran into the issue of wiring the key switch and it seems slightly fuzzy when it comes to making out the wiring. (when I got it, the main wires were removed)
From what I have attached, I think this is the correct wire pattern, but I just wanted to be certain about the wiring before I made a costly mistake!
The guy I got the mower from decided to put a 3 point plow on the back of the mower and use it for his field... the picture tells what happened... he gave me an extra k 241 that I am swapping with. On the upside, at least I can make a cut away model
:D :D
Does the K241 have points ignition or is it breakerless makes a big difference in which ignition switch is used
GB in MN
As for the switch most do not have number on the back side most have letters like S = starter B = battery I = ignition (battery type) A = accessories R = rectifier or maybe unused
Hello Friend! My case 220 has points ignition.
I took a closer look at my switch, and 1 is Stamped G, 2 has no label (as you pointed out, I am assuming it is rectifier or maybe unused? (It is very similar in shape with your outline for R on the the 5 switch model),
3 has a "V" stamped, and 4 is stamped G
OFF -> LIGHTS -> ON -> STARTING
I tested the switch using a multi meter, When it is full switched to STARTING 1, 2 and 4 have power
When in the ON position, 2 and 4 have power
When in the LIGHTS position, 2,3, and 4 have power
Hopefully this can help break this down a bit easier in identifying the wires
Sorry I forgot Case did things a little differently disregard my post I was going by Power king wiring with Kohlers
GB in MN
https://static-cdn.imageservice.cloud/13449401/case-224-wiring-diagram-wiring-diagram-technic.jpg
This is for a 222, but shouldn't matter. It may matter for the other wiring (regulator if you don't have a starer/gen). You should check out casecoltingersoll.com. They have manuals online, the origin of this pic.
