Case 220 PTO trouble
cve
Hi
I have a 220 it's having some PTO trouble develping got it rebuilt a few years ago
Wondering if there is an Electric clutch of some kind that would work.
Thanks Chris
I would atrongly advise against an electric clutch. Right now.....you have the best clutch but like all mechanical clutches, it needs to have timely adjustments along with the replacement of worn parts. I suggest that you join Case Colt Ingersoll dot com. There....you will find a Library with OEM manuals for the clutch. Learn how to adjust and rebuild your existing clutch. Parts are not a problem Aside from the actual clutch, you need to service the linkage that operates the clutch. Bushings wear out and sp dp tjhe holes om tjhe linkage. You have a very old GT and nothing lasts forever but if you look after your 220, you will get years more service from it.
cve, Thats good advice. And I learned that long ago, kind of collecting Case GT's, esp DesertSunset ones. I have a bit of experience with that clutch, probably not close to you,to assist...
