CASE 2290/970 Questions
1175scott
I have a 2290 sn# 9916355. Getting ready to paint it and the front rims are silver and the back rims are power red. All the literature and op manual show the back rims to be silver. Can someone enlighten me as to what color they should be? The tractor has not been repainted to the best of my knowledge. The 970 has a narrow front on it. The pedestal came off of an 830 (threaded caps). I used to run 6.50x16 tires on it. What are the biggest tires i can put on it? Would the 10.00x16 tires off a wide front work? If not can someone tell me what kind of a rim offset i would need? Thanks in advance!
a original 1982 model
cnt
As far as front tires go, 6 bolt hubs will fit on those spindles just fine so you can out on larger tires if you like.
With stock rims 6.00X16 or 7.5L X 15 is as big as you can go. Bigger in any way or size will hit on bottom side when turning. I have 9.5LX15 on a 770 but I had to use 70 series wide front hubs and rims with a pretty good offset to make it work, took a lot of trial and error.
1175scott you have the serial 9916355 2290 that my grandpa owned from 1983 to 2001 if you could please get ahold of me Id like to talk to you! I have gone through a lot of digging to get to this point. I made a post on Facebook and a guy named Sam shared me this link. Please sir my name is Jacob Durcholz and my phone number is 812-639-6263 if you could call or text me that would be awesome! Id love to see some pictures of it. Thanks!
