Gard3599
I am looking at a 2290 that has been setting about 12 years with a blown engine. About a year before the engine blew the transmission was rebuilt. I am wanting it to put in my 2090 that the transmission is bad. Should I be leary of the transmission since it has been setting thus long? I belive it will bolt right up to my 2090. Am I correct on that?
If it was parked outside I would be more leery than if it was parked in a shed. I would check the transmission fluid for moisture as it is already 13 years old and plan on changing it before using the tractor. I think 2090 and 2290 share a frame size with the older 970 and 1070, the 2390 and 2590 are the larger 1370 frame. Do you have a shop and stands to split them both at the back of the engine and bolt the two good halves together?
We had 8 speeds in our 970 s / 1070 s,, when you have it apart, could someone test the iner workings of
the power shift, , that would be a bummer if would not shift all reassembled 🙁
