4240 Turbo
I have a 2294 (504 turbo engine) 7500 hours. The nuts holding the injector pump backed out unfortunately, I cought it and re timed by the manual to 25* and the slots were almost totally maxed out and the tractor seemed to run poorly with smoke and high egt, I re checked by pointer on front and lines inside of timing cover by manual instructions. I am at 5500 feet above sea level and generally give a bit more timing to most engines I have worked on (john deere, case, Cat etc.) and the engines run and start better at elevation. Now, I retarded the timing from 25* to about 23* (almost max retard on the slots on the pump) and ran more poorly and smoked black haze of smoke. It was a cool day here and egts really climbed. I have thermal camera, so verified accurate high temps. Oil is full, exhaust is clear, coolant is full, fan belts are worn but working, engine seems healthy, slight amount of blowby however far from excessive, valve lash set to spec within 20 hours fuel filters new (20 hours) air filter brand new and clean, Turbo seems healthy however I need to hook boost guage and make sure we are boosting, No exhaust leaks so turbo drive pressure is no suffering, Tractor should Not be turned up however I plan to dyno at some point. Now, the timing question, after the initial test of 25* and 23* I advanced the timing to 30* and the tractor ran much better still had high egt. I then advanced the timing 34* (marks are only out to 35*) I then pulled another round, and smoke lessened and egt dropped significantly, engine sounds better and runs better (smoother) is definitely a bit noisier. Sounds more like the "cackle" these case 451 and 504 engines usually have had in my recollection, however is there a potential to crack a piston if there is too much timing? I am discing and a miller disc pulls the tractor plenty hard, but still traveling over 5 mph. Should I be aware of anything running this much timing or should i just put it back where it was and let it run hot and smoke?
