Case 2294 wont move.
IH 466
Posted 8/27/2015 15:04 (#4756252)
Subject: Case 2294 wont move. Quote Reply Alert Edit Delete
I've got a Case 2294 12 speed powershift that out of the blue quiet moving, one moment i was mowing hay and then i shut it off to put fuel in it and then went to restart and it would simply not move. No surging of the engine when putting in the clutch as with all case powershifts tractors do that I've owned and operated, I had a respectable old time case dealer come out and they got it to move and told me it was a electrical short and that they had replaced the circuit board under the shifting counsel with a used one, however this was not the problem and even after replacing it, they did show me while I was there that it was a electrical problem by using a tool that I am not familiar with that while attached to the rely wire in dash they could shift the gears with it, you could hear the engine surge just like it always does and the tractor would go through the gears normally although not moving you could clearly hear it go into gear like it would do normally, however i was not able to stay with them through the rest of the repair so a couple hours later they called and said it was a electrical wire problem and the tractor was good to go, but a couple weeks after i was going down the road and went to a stop sign and it did the same exact thing when going to take off it would not move. I have switched the relays around inside the dash and this did not help, and all fuses look good, any other ideas where my problem is at? hopefully this makes scene, if something does not ask me to try to explain it better and I will.
Check for 12v power at the c-2 and c-1 solenoids with engine running and power shift in first and 4 sp in neutral and ignition switch on. Both should have power to them, if not it is a electrical problem and will just have to be further tested as there is numerous causes. If there is power chances are you have a torque limiter hub failure and the tractor will have to be split at the engine to correct that problem. Rod.
dads 2594 had that happen it was somthing called a electric shift board was the problem. also happened to his 2394 right when we went to look at it at a dealership they drove it in the front row we went drive check it out wouldnt move. after they fixed we went back and bought it good tractors.
Loren
