Case 2394 won't move
Top 50
Case 2394,with a 6 speed electric power shift when I pushed in the "clutch" and shifted power shift to forward tractor wouldn't move. I can put it any gear without depressing the "clutch" pedal. The oil does not surge when depressing the pedal either. What's going on is torque limiter blown? Everything else is fine, hydraulics and power steering are working.
the switch on the top of or bottom of your clutch peddle is not working by the sounds of it.
I think I would play with the bottom one first as it sounds like your clutch is always
depressed. other wise I don't think you should be able to put in gear.
If you do not have that surge when you push in clutch pedal I would say the torque limiter is the problem. You will have to split the tractor behind the engine.
