Hi,i got a 2394 with hydraulic problems tractor quit moving and no hydraulics or steering.Changed the suction tube to the main pump,removed pto and shifter cover and cleaned out the suction screen very little debris on it or inside the tractor.Put in new oil and filters checked relief valve above filters and it took pressure to push it open,used the tractor for cleaning corrals and everything was quiet for a while then the trans filter light started coming on and hydraulics got noisey.Most i used it was 10 hours after cleaning suction screen and changing oil and filters.Oil is hytran and filters bought at dealership.Put a pressure gauge on the oil filter plate and charge pump read 15psi when i started it,15 minutes later it read 10 psi.Is that my problem the charge pump is shot?
