Case2390
Hi,i got a 2394 with hydraulic problems
tractor quit moving and no hydraulics or
steering.Changed the suction tube to the
main pump,removed pto and shifter cover and
cleaned out the suction screen very little
debris on it or inside the tractor.Put in
new oil and filters checked relief valve
above filters and it took pressure to push
it open,used the tractor for cleaning
corrals and everything was quiet for a
while then the trans filter light started
coming on and hydraulics got noisey.Most i
used it was 10 hours after cleaning suction
screen and changing oil and filters.Oil is
hytran and filters bought at dealership.Put
a pressure gauge on the oil filter plate
and charge pump read 15psi when i started
it,15 minutes later it read 10 psi.Is that
my problem the charge pump is shot
So you have nothing to say about my response in Tractor Talk, see attached? If the 94 series is different than a 90 series than please say that, I am a big boy. I have only had a 1070 opened up stem to stern so I do not know maybe you can access that screen well enough by removing what ever you said you did. Just trying to help and learn.
Post in Tractor Talk
Sorry just finished chores,i just answered your question in tractor talk.I moved my question here this morning after your advice,hoping i would get some advice so i could work on that tractor tonight but no advice,so i guess my search continues for a forum with advice.Thanks for your help.
A couple guys are pretty sharp on those Cases on here. May have to run the normal cycle, a lot of guys check here early on week day mornings. Otherwise have you ever posted on AgTalk, if not might give that a try, see link. Definitely a lot more viewing traffic there than on YT. Understood about your answer on the TT section. Good Luck!
AgTalk Machinery Talk
