Case 2470 turbo upgrade
Mike, I replaced mine with one from Blaylock diesel here in Baxter springs, KS. It will max out about 16 lbs of boost. Blaylock also said they could increase the output of the garret if so desired.
the part # they set up for me was 313184.
You can also use a schwitzer 3LM466 but have to use a spacer under the air cleaner and I used a 1/8 under the exhaust flange and am going to put one under the intake elbow at the intake manifold, probably 3/8 to help with alignment problems. I saw maybe one pound of difference in boost pressure.
HTH Tom
