Looks like an MTAI have what I believe is a Case 3 bottom 3pt plow. Can anyone identify make/model? I need a replacement shank/standard for one of the bottoms.
I agree. MTAI have what I believe is a Case 3 bottom 3pt plow. Can anyone identify make/model? I need a replacement shank/standard for one of the bottoms.
Wear parts for thec14" eagle bottoms are few and far between. 16" points are available and will work on the 14" bottoms. Moldboards, shins and landsides are generally not available unless you luck into some NOS old stock. As far as I know, no one is currently producing new parts.Where can replacement wear parts be purchased for this plow?
Moldboard - SteelWhere can replacement wear parts be purchased for this plow?
Connor., does the 16" steel moldboard fit the 14" bottom? I knew the 16" shin and shares would work. Thanks for the information.Moldboard - Steel
Shin
Landside (Oliver but fits Case too)
Poly Moldboard Cover - This is for the Case EX bottoms and will fit both 14 & 16" moldboards. They can do them in other colors than yellow too. The title on the page is wrong it is not CaseIH. It is a real J.I. Case moldboard pattern. They will also make custom ones if you send them the old moldboard.
Rib Share
Yup, sure does.Connor., does the 16" steel moldboard fit the 14" bottom? I knew the 16" shin and shares would work. Thanks for the information.
Moldboard - Steel
Shin
Rib Share
All the 14" wear parts fit the 16" plow as both frogs are the same. CASE has crossed all the 14" part numbers to the 16" part numbers, but have eliminated all but the shares. shoupparts.com has the Shares and Moldboards. Be sure to order the "4 bolt share".Where can replacement wear parts be purchased for this plow?
I do not think anyone makes Case trashboards anymore. You may need to find parts plows to get them from. There may be trashboards from other brands that fit but you will have to match up bolt holes and other dimensions.Conner - Do you know which trashboards and coulters fit this plow?
Conner - The Landsides you reference did not fit this plow. The bolt holes do not line up. The Ribs and Shins worked great.Moldboard - Steel
Shin
Rib Share
