I have an abused Case 310B B/L. The Crank pulley was assembled without the four buhings in the pulley end coupler connection, the key is sheared on the crank, the end nut (square 1/2' hole to tighten and undo is ok but the pulley wont pass by the two cast pieces in front of it....so how can I put the nut back on and provide enough hold on the crank without the key that it will turn the pump,waterpump and alternator? Have to get this thing back and running. Have ordered the 4 bushings for the 7/16 bolts but need some help with ensuring that no slippage occurs between the front crank and the pulley.
Thanks a lot
Ron
Thanks a lot
Ron
