Case 311 three point hitch
Trying to get an old case 311 resurected. The three point hitch arms won't go down. They seems to be stuck in the up position. I can't seem to find anything wrong with it. Any ideas on what I could try to get them to release. Thanks
Piston seals may have rusted to cylinder bore, if it sat a long time in the up position. Loosen the fitting on the pipe feeding the rockshaft housing, and apply some weight to the 3pt. arms. Perhaps another tractor with a loader to apply down pressure. If the armes drop easily when the fitting is loosened, I would check the arm and shaft under the fuel tank, to ensure the control lever is stroking the valve spool.
Loren, the Acg.
