Gary in Cheney
Just about finished with my 311 restoration but can't the thing running again. I figured I should start new with the electrical so I changed the wires, distributor cap, plugs and everything in-between. Problem is the thing won't start.
Here is how I re-timed - book says that firing order is 1-3-4-2
1. Hand cranked clockwise so that timing mark is 7/32 before the DC mark. I believe that is the #1 piston is all the way up.
2. Checked the position of the points. Rotated the distributor so that pressure on the rotor shows the points just starting to open.
3.Mounted the distributor cap. Position of the rotor is noted to be for #1 plug.
4. Placed plug wires back into distributor in 1-3-4-2 firing order going clockwise from #1 on distributor.
5. Firing order is from right to left (#1 being by the radiator)
Other settings and info.
Points are gapped at .020
Plugs are gapped at .025
-Carbeuretor has been checked and serviced with a new carb kit.
I did notice that my fuel may have been contaminated a bit with a little rust due to the fuel tank sitting empty for an extended period of time. Have not flushed tank since but after draining a little fuel the color went away.
Brand new battery turns the crankshaft. I've checked and all 4 plugs are getting spark. I do get a little combustion but not much.
Looking for other things to check or any corrections to how I retimed this old boy.
Thanks for any sugggestions.
Gary
Gary
