Case 320 backhoe
Yotetalker
Does anyone know much about the case 320 backhoe shuttle shift tranny numbers on right side says G1202. The problem im having is going from forward to reverse the shift fork will kick past the shift lever (square rod with hole in the bottom ) is it that i need a new rod or fork or is it out of alignment...i can out it back right way and it will be good for a few but does it again... any help would b greatly appreciated..i would post pics but dont know how ....Thank you
The 16881 kicks pass the 16638. The 16881 has a hole drilled in the bottom of it. I didnt know if there should b something there.. and thank you for the pic and the info. I will pull it apart today and look at it again.
