toddsmith23
Hello everyone - New to the forum, and to the Case 320 loader/bh.
I purchased the '58 machine recently, it had been sitting for a few years outside on a farm. Everything seems to work pretty well, starts right up, hydraulics worked fine.
I made a rookie mistake and didn't look at the hydraulic fluid closely, after getting it home and playing with it, i checked the fluid and saw that it pretty milky and needed to be changed. I'm assuming it accumulated a bunch of water while sitting in the elements.
What's the right way to dump this fluid and replace it? I was thinking (read this somewhere) raise the hoe and loader, drain the fluid from reservoir, lower the implements and drain the rest and let it sit overnight. Refill, run till hot and check again. Repeat if necessary. I know that's expensive, but.. the alternative could be much worse. Thoughts on this? (also clean reservoir and filter)
Another question i have is, i bought the 320 service manual however it covers only 210B, 310 tractor/crawler, 430 & 530 CK Forklift, 430 & 530 TLB. I'm guessing the 320 was based on a tractor and case installed a loader/hoe and called it a 320. What tractor model does the 320 use, assuming i'm right about this?
Thanks in advance and glad to be aboard!!
