Case 320 Transmission oil
RJZAMISKA
Have a 1958/1959 Case/Terra-Trac 320 bulldozer, Ser#4948. Question is what is the correct fluid for the transmission? Will the Tractor Supply- Ford 90# mineral oil work or will this be to thick for the brake bands. Any suggestions appreciated?? Regards Ray
Tractordata.com Nebraska test709 Click on the link. I am sure you will find the particular lube specs. CM Keep us apprised.CM
I think the difference between the 80 weight mineral oil
stated in the tractor data test is, and the 90 weight would
not be an issue CM
