Case 380B Hydraulic Power Block
Michael Holt
I am looking for a case380b Hydraulic Power Block for a KMW Loader System. It is an Aluminum housing that allows the hydraulic hose to connect to the tractor transmission and supply hydraulic power to the the KMW loader. It is located on the right side under the seat at the top of the transmission.
That's the same as a David Brown 885, right? I got mine from Elmer Landsman, who is (or used to be) on this board frequently. Search Elmer here on this board, his email will come up. He's up in Canada, not the Elmer's Repair in Kansas.
I thought the 380B was actually a Case-IH 485 (ironic how a Case industrial tractor is an IH ag design)
IF that's the case, perhaps the power beyond plate that is used on the AG version will work, the hose for the loader on those comes out where you describe.
I've never been able to find much info on the 380B, but the ROPS on the 495 says "fits 85, 95 series and 380B" on it.
You are exactly right. I was always told this was orignally an AG tractor made like a industrial tractor. I bought it mainly because it was a working tractor with a live PTO on it. I love the tractor and it puts out the work. It is a hoss! But without this block or adapter plate right now, I can't use it.
Thanks for the replies. I am still looking for the Hydraulic Power Block. It is not a Case part but will be the aftermarket part for an implement. I did not find Elmer Landsman either.
A man from Wisconsin sent me a power block but it has no "O-Ring" ports in it to seal off the fluid. I could possibly have the ports machined into the piece but it seems to be a lighter weight piece than the one I have now. It will have to come off of a salvaged tractor. Any one know of any big salvage yards? The one I got came from ASAPAGPARTS. They have been very helpful, but we have ran out of options.
I have a 380B case and cannot find where to add hydraulic oil at. Help....thank you
[q
uote="Michael Holt"](quoted from post at 13:27:37 04/04/09) I am looking for a case380b Hydraulic Power Block for a KMW Loader System. It is an Aluminum housing that allows the hydraulic hose to connect to the tractor transmission and supply hydraulic power to the the KMW loader. It is located on the right side under the seat at the top of the transmission.[/quote]
