Does anyone know why Case changed the drag link/tie rod arrangement on general purpose big 400 tractors? From looking at the parts diagrams, the double drag links behind the axle was used prior to serial number 8069698 (in 1955) for the 53-82 version. Then this width option switched to the single rear drag link with a tie rod in front of the axle. The other width versions in the book all show the front tie rod, with the exception of the high clearance version which evidently retained the two rearward drag links. Protecting the rods behind the axle seems like it would be better, but clearly Case kept with the front rod version for many years so I must be missing something. Cheaper? Better geometry? Tighter turning radius?
This post was edited by namdc3 on 02/19/2022 at 06:47 pm.
