Buck Carter
Recently Aguired Case 400, the 3 point lift doesn't seem to work. Fluid level is good. Took hose off cylinder , no fluid. Need advice !? Thanks
Pretty extensive coverage of the Eagle hitch hydraulic system in the IT manual. So many possibilities. relief valve not seating. Worn out pump. Common for those to have run low on fluid and virtually wore themselves out. You really need a book. gobble
assuming its a round nose? You need Adirondack case guy or Jon F they are pretty good on them. On the case board John Salie and Livingston would be able to help.
On thing is the lever is reverse of what most use and forward is up. Otherwise is there pressure on the other valve? If so then it's a valve issue. Not a troublesome system and I've never heard of that issue. The pumps do get worn out, but if that was the case you would still get some oil. For total failure about the only thing could be broken drive components or the rubber seal between the pump and pick up tube. Just pull the hoses and the 4 bolts and the pump comes off to check those.
