A couple of questions on this tractor. I"m pulling the engine ( Gas) to rebuild/reseal, how does the torque converter come off the flywheel? Engine is still bolted to bell housing, do you pull as a
unit then remove converter from flywheel after its apart? I dropped the oil pan and see no bolts holding converter to the flywheel or a plate on the bell housing to access that side. I don"t want to
mess anything up. Second question, is the 411b the same tractor or share parts with other models? I need a gas tank and have searched the internet and have found nothing yet. Thanks, Kenny
