Case 430 gas engine exchange
claude720
Have a 430 gas with hole blown through #3. CWG K110 cast into the block behind distributor. Found gas swather with CWG E64 cast into the block. both are 3 bolt starters and both are approx 19 back to front of block. Will they exchange or is more info needed? Many thanks in advance.
It should fit, that motor is a 124 or 126 cubic inch motor, you mite be down on power a little. I have a complete 148 motor core from a skid loader, probably will need to be rebuilt I would part with. 7153082163
