thomas reed
Iput new seals in my charge pump and changed the oil in trans. filters and cleaned the screen put new hoses on suction line. Filled the suction hose with fluid and can not get the pump to pick up oil fron trans. the pump did not look to be that worn seals were hard. Not had dozer long just changed all the fluids and fliters before putting it to work. It would not move for a little while when you first started it when I got it thats why I put seals in pump. Is there some trick to primming the pump that I have not done I filled the line 5 or 6 times. Do you have to put it in gear to get pressure I tried in gear and not but was afraid to let it run to long about ten min. all together. Please help thomas
