CASE 450B PUMP
AC Tim
I needing to rebuild the hydraulic pump on a Case 450B dozer. Is
this a big undertaking? Or is it something the shade tree mechanic
can do? I cant find any info on how to do it.
Thanks Much
I assume you're talking about an aluminum Cessna gear pump up front? They are not rebuildable. They are basically "throw-away" pumps. You can get new for $250-$300 if you shop around. Very common pump used by Deere, Ford, IH, Oliver, etc.
Probably a generic SAE two-bolt mount with a 7/8" X 23 spline shaft.
