case 450B torque converter leak
Has anyone had trouble with torque converter leaking? Oil drips off cross member under the converter. Thanks for any help anyone can give. How hard is the converter to rebuild?
You could have a leak on the output shaft seal or any of the pipes that are connected to the torque,you will have to locate the leak and that may involve taking off the guards to find it.
AJ
the lines are not leaking and have new output shaft seal. When you take the cover off that goes on the front lower half of the converter houseing where the ring gear is there is converter oil inside of the houseing wright above the cross member.
There should be no oil in the flywheel housing,there are several places oil can leak from the TC,any internal leaks will require tear down,if the machine is pushing strong it may only need resealing.
AJ
