Case 480 LL
Best description.....almost BULLETPROOF. 40 yrs. old and most have been worked to death & will still do a days work. We had one for 20+ yrs. & should have never got rid of it. The 188 engine is a little beast.
I went over and looked at it 2WD with some type of fancy grader box on the back,but the tractor isn't running right throttle won't open up and either has an injection problem or maybe head gasket.The seller said it was the throttle stuck I told him if he gets it running right to give me a call.I like the loader too but doubt I'll hear from him.
It has a MOD hitch on it from the sounds of it,, those alone are worth 1500-2000 plus the box blade if it has the rippers intack,, I have seen the hand throttles seize up on them as no one uses them,, what makes you think it has a injection pump or head gasket issue? I am guessing the foot throttle works? hopefully you hear from him,,
