Case 485 remote hydraulic connectore
DirtMover
Hi all,
Attached a post hole digger to my Case 485 tractor and drilled approximately 35 holes. I was wanting to attach the down pressure unit, but there is a mismatch on the hydraulic connectors. The rear remotes are 7/8-14 female. The attachment has a Safeway S41-2 (1/4) on main hydraulic line and a Bruning (no Part number) on the return.
Whats the best route for me to take?
1. Change out the tractors female adapters to match the post hole digger?
2. Change out the post hole digger to 7/8. Im guessing Id need a reducer as well.
3. Change both out to a standard size? I might like to add some other attachments later. Maybe even a 2250 loader if I could find one.
4. Would it be better to just make adapter cables with 7/8 male on one end and a female connector for the attachment lines?
Im looking versatility as well as not spending a boatload. Ive attached some pics to help.
Thank your for your time.
<video width=90% src=https://www.yesterdaystractors.com/cvvideos/cvvideo129165.mov controls>http://forums.yesterdaystractors.com/cvvideos/cvvideo129165.mov</video>
First off if you want to get a loader for it and still use the rear remotes you want to get a power beyond plate which goes on the end of the valve stack. This will let you use your loader with oil flow full time and not tie up your remotes in back so you can have your cake and eat it to so to speak. You would be able to lift the loader and still lift a disc in back without unplugging the loader hoses. I would put like, tips on your hoes there and go to work. If the end of the digger auger is not going in the ground you need to sharpen or adjust the auger in some way. I had a friend of mine complain about his not going in. I welded some pieces of plow point on at a slightly steeper angle with the edge sharpened so it was not so thick he said he had to stop letting it drop or he could not pull it back up. Worked fine when I got done. I don't think that Bruning tip is compatable with the ones on the tractor. Some tips have a different length from the groove to the tip end and will not lock in or will not push the other side in or not push their side in to let oil flow. Some even have stiffer springs in them making them not work. I have had a problem some times with the ball and the pointed tip not working and would not let things go up or down.
I once bought a used mower conditioner from a fellow who was in the dirt business. I struggled with how it lowered for two seasons before I found that the tips on the mower were a type common to industrial use while my tractor had Ag type connectors. I suggest that you decide what type of implements your 485 will be used for and go with that type of fitting on your tractor.
Looks like the two male tips fit in your 485 now? They look like standard ISO tips, and the 485 uses ISO couplers.
You can reach behind the coupler and pull it backwards (away from tractor) to make things easier to connect.
In any case, I'd be changing an implement connector before I'd change the tractor end.
